show ports anomaly
show ports {port_list | tag tag} anomaly {no-refresh | refresh}
Description
Displays statistics of anomaly violation events in real time.
Syntax Description
port_list
Specifies one or more ports or slots and ports.
tag
Specifies an 802.1Q or 802.1ad tag value.
no-refresh
Specifies a static snapshot of data.
refresh Continous refresh of output.
Default
N/A.
Usage Guidelines
If you do not specify a port number, range of ports, or tag value, statistics are displayed for all ports. To clear the counters, use the clear counters ports command. The default display is a constantly refreshing real-time display. If you specify the no-refresh parameter, the system displays a snapshot of the data at the time you issue the command.
This command takes effect after enabling anomaly-protection.
The tag value may be associated with either a VMAN or a VLAN.
The following command displays real-time anomaly statistics on a switch:
show ports anomaly
Following is sample output from this command:
Port Statistics Thu Nov  9 22:44:31 2006
Port Link       Rx Pkt ============ Anomaly Violation =========
State Count L3 Count      L4 Count     ICMP Count   Frag Count
1 A 191585 1 2 0 0
2 R 0 0 0 0 0
3 R 0 0 0 0 0
4 R 0 0 0 0 0
5 R 0 0 0 0 0
6 R 0 0 0 0 0
7 R 0 0 0 0 0
8 R 0 0 0 0 0
9 R 0 0 0 0 0
10 R 0 0 0 0 0
11 R 0 0 0 0 0
12 A 178024 0 0 0 0
13 A 196956 0 0 0 0
14 R 0 0 0 0 0
15 R 0 0 0 0 0
16 R 0 0 0 0 0
17 R 0 0 0 0 0
Link State: A-Active, R-Ready, NP-Port Not Present, L-Loopback
0->Clear Counters  U->page up  D->page down ESC->exit
This command was first available in ExtremeXOS 12.0.
The tag value was added in ExtremeXOS 12.4.4.
The refresh keyword was added in ExtremeXOS 16.1.
Platform Availability
